Topic: Over-responsive resetting crossfade/ gain sliders
Hello, my VDJ does this thing where a) the gain sliders are initially set to 0, and b) if i slide the gain slider or the deck slider, and i slide just a bit off (too much over) then it resets all the way in the other direction. It seems to be over-responsive. Any setting to fix this?
geposted Tue 28 Mar 17 @ 7:28 pm
