Is it compatible?
geposted Fri 31 Mar 17 @ 6:22 pm
Yes it is
List of supported controllers:
http://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
Mapping in the software
geposted Fri 31 Mar 17 @ 8:45 pm
I can not connect my M-audio exponent controller to the virtual dj, I have a license, but for some reason the program stopped responding to it, I already managed to use it before and gave this error out of nowhere. what do I do? Can someone tell me? and there is one more thing, in my virtual dj I can no longer connect to the internet to log into the account, but only in the virtual dj, all the computer programs outside it are connected on the internet. at that exact moment I asked the question I could not log in to the virtual dj because it says that I can not connect to the servers.
geposted Sun 26 Aug 18 @ 4:55 pm
This usually happens because you have installed an illegal cracked version of VDJ.
You can find tools for fixing this in the download section - select the 'others' category then search for 'host'.
geposted Sun 26 Aug 18 @ 6:02 pm
