Hello, I have just upgraded to a Demon MC4000 controller, and I am having the problem that even with channel cue on, both channels play out of the speakers. I just can't see what I have set up (or not), for this to be the case.
Can anyone help?
Can anyone help?
geposted Sat 01 Apr 17 @ 12:07 pm
Problem solved, it was a set up issue that is now resolved.
geposted Sat 01 Apr 17 @ 12:36 pm
Yes, that's just as it should be. Activating cue doesn't switch off the output. The idea is to cue tracks with the channel fader down.
geposted Sat 01 Apr 17 @ 12:42 pm
