It would seem the ability to cull (delete) a singers history playlist would be available... if it is I can't find it.
Other than deleting the entire playlist there is no right click option in the list to remove a song from the playlist?
What am I missing here?
geposted Thu 13 Apr 17 @ 11:04 pm
you can load (entire list) to the automix/playlist then delete/remove and re-save it.
This is the way to edit any history that's been created.
The Playlist has the option to remove
geposted Fri 14 Apr 17 @ 1:52 am
