hi. i have numark party mix. on this controller there is 4 pads and button that change function of the pads so i can change 3 function and at each one i can use 4 pads. i want to map i function to effect, on for cue, and one for sampler. i didnt understand who to do it.
additionally, when i presse effect i cant see his strengh without presse with the mouse on it. the problem that i cant change strengh like that.
i wish for help
tnx
i wish for help
tnx
geposted Tue 18 Apr 17 @ 8:32 am
I have a problem, I don't find the mappers of numark party mix and I don't know how to do, because there is a botton that says pad mode, and it has the effects, cues, loops and samplers...
And I don't know how to map this. If anyone could help me, I would be so grate :(
geposted Tue 26 Dec 17 @ 9:14 pm
The mapping is built in to VDJ. The Party Mix is a natively supported controller. You do not need to install a separate mapping file.
geposted Tue 26 Dec 17 @ 9:18 pm
