Topic: Folder order on External Drive
Running 8.2 on a MacBook Pro with Retina. When I go into the HD files (through Volumes on the left), the folders are not in alphabetical order. I tried reset sort order but nothing changed. Am I missing something?
geposted Tue 18 Apr 17 @ 12:44 pm
There should be a "order" file in ../VirtualDJ/ or ../VirtualDJ/folders.
Check these file and delete it if it contains the wrong order.
geposted Wed 19 Apr 17 @ 8:59 am
Will try that, thank you
geposted Wed 19 Apr 17 @ 9:01 am
Hi - just tried that, didn't work unfortunately..
geposted Wed 19 Apr 17 @ 9:10 am
there will be a .order file in the any folder that is out of order, have a search
geposted Wed 19 Apr 17 @ 11:11 am
