Topic: XDJ-1000 mk2
Hi
I just bought 2 XDJ-1000 mk2 thinking that there would be no issues with VDJ 8. Think again :-/
When can I expect native support for this unit?
Has anyone made a costum mapping yet ??
geposted Fri 21 Apr 17 @ 3:02 pm
Am I the only one who has this problem??
I would imagine most people spending that kind of money check they are compatible and supported first.
They look visually very similar to the mk1 units, have you tried that mapping. If you have some knowledge you may be able to just tweak that. You may need to create a definition file though. Unless you have that skill then you will have to either wait for it to be mapped or exchange for something that is supported.
Hello,
I have the same problems. Its impossible to copy mk1 mapping for mk2 device.
Hi, does anyone has this mapper XDJ-1000 MK2 mind sharing please.
There's no mapper for XDJ-1000MK2 yet.
I did manage to map a few basic buttons to work such as cue, play, nudge, pitch slider, master tempo, hot cues & loops, but can't & unable to command the jogwheel.
Any ideas how to map the jogwheel? Please help.
Very basic Jogwheel controll should be possible by either using "joghweel" or "touchwheel" action.
Depending on the jog type. I think you should try "touchwheel" first.
Maybe have a look how similar controllers are mapped.
Official support for XDJ-1000MK2 will come very soon. So just be a little patient! :)
Thank you, noted.
Thank you
