Topic: HIDE / UNHIDE
Hi. I recently noticed that if you right click a folder you can select 'Hide' and it will disappear. However, I did this to a couple of folders I would like back. How do you get them back?
Thanks
geposted Fri 28 Apr 17 @ 6:36 am
Never mind. I figured it out.
geposted Fri 28 Apr 17 @ 6:37 am
sidazPRO InfinityMember since 2014
how do you do it ?
geposted Tue 11 Jul 17 @ 11:14 am
If it's a sub folder you can often right-click the root folder, and then get an option to show it again
If it's a root folder you can use the little gray dot on the bottom left of the screen, and choose "root folders"
There you can choose which ones you want back - or click "Reset root folders" to get everything back
geposted Tue 11 Jul 17 @ 11:25 am
