Topic: Virtual Dj DirectX Failed to Initlize Error
Windows 10 Creators Update 1703 15063.250 x64bit
Clean Install
Problem is everytime I try to open Virtual dj, I get Directx failed to iniltize error, this is my 3rd clean install this month, any ideas on fixing it permently so doesn't happen again, very aggravated, have high blood pressure and liver problems, I don't need this aggravation, almost ready to demand a new PC with Intel Processor and Nvidia, so I won't have to deal with crappy AMD Radeon Drivers either, video card is Radeon R7 240
Drivers installed
AMD Relive Editon Crimson 17.4.4 (latest)
Also tried older drivers, no luck
geposted Sat 29 Apr 17 @ 4:10 pm
install directx 9
i have same drivers and same windows and all is working here
i am guessing you have some plugin that needs the dircetx 9
geposted Sat 29 Apr 17 @ 5:51 pm
Went back to AMD Relive Crimson Edition 17.4.1 drivers, maybe my card didn't like the 17.4.4 ones, but after each restart it's opening fine now, so I think I finally got it solved, as I tested it a few times already to make sure, and it seems to be working properly now--thankfully spent hours trying to get it to work properly, thankfully I didn't have a dj set while I was trying to fix it
geposted Sat 29 Apr 17 @ 5:57 pm
