Topic: VMS 4.1 VU Meters
Hi
Got a problem with my VMS 4.1 After plugging it in yesterday I noticed that the left hand VU meter was showing signal up to -7db and flickering with no input source connected.
Once everything was hooked up and I put signal through the controller I found that although the sound through the speakers seemed to be fine the left hand VU was still not working correctly and occasionally maxing out into the red.
Although it doesn't seem to be an issue on the output it's a problem I'd rather not have. Has anyone had similar problems? Did you find an easy fix or is this a trip to an engineer?
Any help greatly appreciated
Mike
geposted Mon 01 May 17 @ 8:57 am
bogartPRO InfinityMember since 2004
Get hold of ADJ. They can help you check out the controller to see if that is the problem.
geposted Mon 01 May 17 @ 1:15 pm
