Hello,
Just I wanted to share this issue:
for the version 8.2 b3710 the slicer and the loop roll on the 4th deck are not working when pressing the pads, but all other decks are working fine.
When rolling back to the b3696 everything is working fine and smoothly.
By the way I am now on the demo period for a DDJ-SZ.
Thanks
Thanks
geposted Mon 01 May 17 @ 8:43 pm
Same problem here, with a Reloop Beatpad 2
geposted Tue 02 May 17 @ 9:11 am
Same issue here as well
geposted Tue 02 May 17 @ 6:21 pm
The devs are aware and working on it. You can go back to build 3696 if you want a quick fix:
http://www.virtualdj.com/download/build.html
geposted Tue 02 May 17 @ 7:01 pm
thanks for the fix on the build 3731
geposted Thu 04 May 17 @ 8:40 am
Similar problem here. Using DENON MC4000. Looproll not working on the right deck. Can anyone help?
geposted Sun 07 May 17 @ 9:32 pm
This was only a bug in b3710.
If you are on that build, please go to b3696 (Public Build) or b3731 (Early Release) as described above
If you are not on b3710 your problem is something else
geposted Mon 08 May 17 @ 5:51 am
I am using b3710. So that's the reason. Thanks! I will wait for an official update
geposted Mon 08 May 17 @ 5:19 pm
