Topic: Audio skips on latest build of Virtual DJ 8
Good Evening -
I've used Virtual DJ for about 10 years and have never had an issue -
Just a few weeks ago, when using Virtual DJ 8 and not connected to the internet, each song played will skip one time. After turning back on the WIFI, do not have an issue. I am running the latest version of Windows 10 and no issues reported on the WIFI. I am using the Numark ASIO sound card with latest Windows 10 driver. I've tried a different sound card and same issue. Running setting at 256 samples as I always have. Please advise of resolution of this issue.
Thanks,
Craig
geposted Thu 18 May 17 @ 8:08 am
geposted Thu 18 May 17 @ 11:38 am
Thanks for assisting and appears to be resolved.
The laptop was looking for an update to Windows 10 Creator. Even though off line, the alert would keep appearing. I went ahead and updated to Windows 10 Creator and is now stable whether online or offline. Like I said, this is the first time in 10 years that I had a skipping issue.
geposted Mon 22 May 17 @ 11:08 pm
