The 4trak that I use is not fully connecting to VDJ. IS the mappers or drivers that cause this issue. One of my layer lights on the right side won't light up at all. I'm not very computer savy. Please inform me of what I can do. I have updated the drivers but maybe there is an easy solution that I just don't know..
geposted Fri 26 May 17 @ 12:07 pm
Is it just the right-side Layer button that doesnt light up or more ?
geposted Fri 26 May 17 @ 8:28 pm
I have the same problems
1 the layer led will not work for B or D
2 mapping has layer B controlling deck D and layer D controlling deck B
I made some changes to my map to correct the deck control but I don't know how to make the layer led work
geposted Wed 31 May 17 @ 6:52 am
@gman0186 and @returnblock , please check your emails and reply with your feedback. Thanks
geposted Wed 31 May 17 @ 6:54 pm
im having somewhat the same issue...but mine doesnt work at all...if theres a soultion to allow me to use myNumark trak can i get a email about what i can do please darealistdj@gmail.com
geposted Thu 22 Jun 17 @ 6:34 am
For me the same problem as Returnblock.
I managed to let the B/D button, switch to the corresponding deck, but it would be great if I can switch on the light and change it from blue to green, just like A/C does.
geposted Tue 27 Jun 17 @ 8:55 pm
