Topic: 10 minute timer
Could I just buy the non-pro license which is $99 for the 10 minute limit to go away so i could use it as long as I want for my ddj sb2.
geposted Sun 28 May 17 @ 11:07 pm
Yes you could just buy the $99 license - if you will only be using your DDJ-SB2 at home.
If you're a working DJ who's being paid for regular gigs then you'll need the full Pro (Infinity) license.
Also bear in mind that the $99 license is tied to the controller you buy it for, so if you change controller it means buying another license.
geposted Mon 29 May 17 @ 8:34 am
