Topic: script for auto loop
I want to adjust the auto loop function on my controller so if no loop is engaged, when selecting auto loop it will go to a 4 beat loop. Then if I select auto loop with any loop length engaged, I would want it to cancel the loop. I am not familiar with a var script so hoping someone could help me out. I was thinking the following script would work, however it doesnt.
var 'loop' ? loop_exit : loop 4
if no loop is engaged it will jump to a 4 beat loop as expected, however if a loop other than a 4 beat loop is already engaged (e.g. 8 beat loop) and I select the button, VDJ will first go to a 4 beat loop and then disengage if I select it again. How can I amend the script so it will disengage the loop after hitting it once?
thanks!
geposted Fri 02 Jun 17 @ 1:59 am
simply ...
loop 4
Sorry, I should've mentioned I tried that already. Its the same results; if on a 8 beat loop, selecting the key will first bring it to a 4 beat loop then disengage if selected a second time.
Try this:
loop ? loop : loop 4
Cheers! That script functions as I'm describing. Thank You!
