Topic: BUILD 3760 reanalyzing my songs
Hi! since BUILD 3760 VDJ is reanalyzing all my songs I load on a deck or into the automix playlist, even if they have been analyzed before. So severla BPM values are changing.
Any idea why this is happening?
geposted Fri 02 Jun 17 @ 6:31 am
The bpm analyzer has been updated, so any songs that have not been scanned with the new analyzer will be scanned again
If there are any bpm's that were correct before, but are wrong now, please let us know the titles so we can investigate more.
Is it possible to build a filter-folder for files to scan with the new BPM-analyser?
You don't need a filter folder.
Just drag the files on "Automix" and all tracks that are not scanned with the new scan engine will start scanning automatically
Thank you for the hint ;o)
If rescanning songs , could this change the timing of cue points or other POI 's ?
In 3761, it could move automix points that have not been manually moved earlier, and adjust bpm/phase if it had not been manually changed.
Other POI's, automix points that have been manually adjusted or bpm/phase that had been manually adjusted will not be affected by the automatic rescanning.
Adion wrote :
In 3761, ... or bpm/phase that had been manually adjusted will not be affected by the automatic rescanning.
Reassuring.
I was using Automix fade intro/outro 0 sec and it still changed my manually set POI's.
I let the computer run all night re-scanning my entire library and it is still scanning when I move a song to the automix
I am using Automix to rescan my songs and adjusting the cue points after it scans. If I use a song already scanned in Automix it will not rescan it...
ohshit wrote :
Reassuring.
B3780 is a disaster for me, numerous files that I have manually affix BPM to has now been changed after this update. After prior assurance that they will NOT!
BTW these changed files are NOT reanalyzed, just update b3780 , reopen VDJ and I see BPM changes I never wanted.
BTW experimentalBeatAnalyser is set to NO
What now, go back to previous update?
Will this save my prior BPM setting? This is what I want.
Yes, build 3760 was just implemented and thought this was an issue. When moving a file to Deck 1 or Deck which is set to Auto Cue at 0db, the software does not re-analyze. This only happens when moving to Auto Cue? Why is that? Should it re-analyze on both the decks and Auto-Cue?
Update - It is analyzing for Deck 1, Deck 2, Sidelist, and Automix. So, this is a new BPM, etc analyzer?
ohshit wrote :
ohshit wrote :
Reassuring.
How do you manually edit your bpm usually?
We were not able to find any way that would overwrite them with the automatic scan.
I think it would be much better to have a filter folder. That way we can actually see which files (and how many) need re-analyzing.
With your workaround method, we have to drag every file in our collection to Automix, because we can't tell which ones need processing*.
* if you hold the mouse over the 'audio' icon to the left of each file in the browser, it does say 'not' analyzed' - but I'm not prepared to do that for every single one of my files. There needs to be an easier way.
You make it sound like you have to drag every individual file, but you could just press * in the search field, use CTRL+A and drag all files at once.
Also, why do you need to know in the first place? It will happen automatically when needed anyway, and in the browser it probably won't give you much advantage.
It's just that (to me), putting all the files into Automix seems a strange way of going about it.
Why don't these files show under isscanned=0 if they need rescanning? That would make sense, but the 'not analyzed' message in the tooltip is the only indication that the files need scanning again.
I know it's not a big issue, and that eventually they will all get rescanned, but putting them in Automix? Spock would say that it's illogical. :-)
Also, a pop up message should have appeared letting users know that files needed rescanned because of the changes.
There have been literally hundreds of posts about this on various groups and a major change like this should have been highlighted to users a bit more.
kradcliffe wrote :
Also, a pop up message should have appeared letting users know that files needed rescanned because of the changes..
..and the option to ask "Do you want it rescanned"?
