It seems like fast forward + rewind during playing a song has changed, now the beat meter keeps sync with BPM and completely ignores the velocity of the jog wheel.
This is my shift button binding:
shift & deck left wheel_mode 'search' while_pressed & deck right wheel_mode 'search' while_pressed
This turns on "search" mode (really fast fast-forward and rewind) on the jog wheels -- compare this between 3710 (what I'm used to/expect) and 3731 (or later) which does .... weirdness.
I've reverted myself to 3710 and turned off auto-updates, so this is "fixed" for myself, I don't know if this is a regression or a "feature" that I just dislike :) If it's a feature, can I have a toggle switch in options to put it back the way it was?
Thanks!
Thanks!
geposted Sat 03 Jun 17 @ 12:08 am
