VDJ8.1
Newmark Mixtrack Edge
Audio setup as.....
master: Speakers (Realtek High Defibation Audio( (WASAPI) chan 1 & 2 (computer headphone out)
headphones: 4-Mixtrack Edge (WASAPI) chan 3 & 4 (Headphone jack on mixtrack)
This setup worked perfect in VDJ7.
Master output is perfect, (slider fades from decks as it should)
In the headphones, I hear both the CUE (selected with the PFL), and the Master output combined together. Almost impossible to mix. When I adjust the mix/cue control, It just turns up and down the cue. Master stays the same never goes up or down. I need to remove the master out of the headphones completely. Any suggestions? Everything appears to be correct as far as I can tell.
Audio setup as.....
geposted Sat 03 Jun 17 @ 2:52 am
Try the exclusiveAudioAccess setting to Yes (from VirtualDJ Options tab of Settings.
Make sure the Mixtrack sound card is not selected as default device for your OS and is properly set in Quadrophonic mode
http://www.virtualdj.com/wiki/Pre-listening%20with%20headphones%20with%20Sound%20cards%20without%20ASIO%20drivers.html
geposted Sat 03 Jun 17 @ 3:49 am
You could also just use the Mixtrack Edge for both outputs and not involve your computer - which is how it's supposed to be used.
geposted Sat 03 Jun 17 @ 7:50 am
