This happened about 4-5 days ago, after one update, the standard 2 deck or 4 deck is 1/4 grey in the bottom... At least 2 updates ago. b3761 now.
geposted Sun 04 Jun 17 @ 5:38 am
Do you have experimentalSkinEngine turned on?
geposted Sun 04 Jun 17 @ 7:00 am
Yes, actually I turned that on, and now the grey area disappeared when I turned it off. Thanks. Btw, what is that experimental skin engine about? I was thinking maybe faster skin response or similar...
geposted Sun 04 Jun 17 @ 8:40 am
experimentalSkinEngine makes skin drawing faster, so graphics will be smoother on slower machines, and less power is consumed.
On modern pc's it even allows to increase skinFPS to 60 at similar gpu usage compared to 30fps with experimentalSkinEngine off.
The reason it's still experimental is that as you could see there may still be some graphical glitches that need to be fixed.
geposted Sun 04 Jun 17 @ 11:07 am
