drivers 1.1.1
does not see the 4-channel ASIO driver...
only the 2-channel WDM driver.
needs double button push in some modes?
the only way is using ASIO4ALL and using the laptop soundcard as headphones.
audio mutes sometimes with 1024 buffer.?
geposted Fri 09 Jun 17 @ 1:57 am
Well, it's really old. Around 12 years old I think, which is a really long time when it comes to digital DJing
It was one of the first ones created, so I don't find it strange that's it not up to par with todays standards when it comes to for instance latency
But if you want to use it (or any other controller) remember that you can't use the home edition license to do so. That will only work for a 10 min test period
geposted Sat 10 Jun 17 @ 12:03 pm
