Topic: Salve option problem
Hello everyone, I have a problem, I use virtual DJs with Windows 10 in conjunction with a Pioneer Wego 4 license with full non-LE, varying options within the settings, these variations are not recognized when the software is restarted, so every time I have to make some settings again. For example, if the "autoHeadphones" function is set to onload this when the software is closed and reopened I go back to no, this option like the others I'm going to modify. Someone can help me to save the options so that when the software is restarted they are stored ??? I tested on 2 different PCs I authorized the folder contained in VirtuaDj documents to all read and write users. But the problem remains. Also tried uninstalling and reinstalling. The strange thing is that the problem is only on the options because other settings are saved. Best Regards
geposted Mon 12 Jun 17 @ 11:58 am
When the controller detection pop-up window appears ("You have connected a DDJ-WeGo 4") click on "Don't show again" checkbox.
That will fix your issue.
The factory pre-defined settings are applied each time this window appears.
Thank's
