Topic: Database copy from PC to Mac
Hi guys, just need a little bit of help. I have copied my database over form my PC to my Mac. I have switched the directories and the " / " for " \ " but it hasn't copied over the cue points. is there something else I need to change to get my cue points back?
geposted Wed 14 Jun 17 @ 9:06 am
If you have done it correctly the cue points will be there. check the filepaths match exactly.
Ok, The directories have been sorted, but just to make sure, which one is the right slash?
No idea as I don't have a Mac. If you look at one of your song properties it should give you the exact file path and structure.
Vdj will automatically convert to the correct slash on reading the database
