Topic: A pair of green digits showing up in the upper left hand corner of the Skin Display as well as the Video Window
A pair of shifting green digits is appearing on the main skin display and the full size video output window??
geposted Thu 15 Jun 17 @ 12:35 am
Do these digit change and show numbers around 30 or 60 ?
If so, check your graphics card drivers. Most likely you enabled a tool / utility that shows the current FPS (Frames per second) of the windows
geposted Thu 15 Jun 17 @ 7:55 am
