I am working on two different computers to set my keycues and edit my tags. When I copy the files from one computer and open it on the other, the information doesn't transfer. What do I need to do to be able to this? I need a backup just in case. I am using V8.2 VDJ Pro Infinity.
Thanks.
Thanks.
geposted Fri 16 Jun 17 @ 12:57 pm
Did you use VirtualDJ to copy the files?
geposted Fri 16 Jun 17 @ 1:14 pm
No. I didn't. Where can I find the instructions on that?
Thank you.
Thank you.
geposted Fri 16 Jun 17 @ 6:07 pm
