Topic: POI editor predefined actions?
Hi, Im want using Freestyler8 with VirtualDJ. POI editor is great, but it is possible create some predefined cue points (not active), which would be visible in every POI editor windows? Thanks
geposted Sun 18 Jun 17 @ 12:44 pm
geposted Sun 18 Jun 17 @ 1:31 pm
Ok but my questions is for "predefined" actions in POI editor, which I create only once. Now I have to :
1) open POI editor
2) create new cue - type "actions"
3) copy some VJD script to Macro action, which run some action in Freestyler8
This I have to do in every songs, which is waste of time...
What I want is
1) open POI editor
2) create new cue - type "predefined actions", which open new select on bottom
3) selected some predefined action
geposted Sun 18 Jun 17 @ 1:39 pm
There are shortcuts to do what you want, one is a pro only plugin, the other is working with the database at text editor level but unfortunately for you, I'm not will to spend the time sharing how with a home licence user.
geposted Sun 18 Jun 17 @ 2:47 pm
Thank you much to your help.
geposted Sun 18 Jun 17 @ 3:06 pm
Just saying that it is possible, that's a good start, you've got to think outside of just vdj and you'll see much repetition can be saved.
geposted Sun 18 Jun 17 @ 6:16 pm
Well ok, thanks. I thought, that via vdjscript it is this possible, but only "hot_cue 1 remix" works. Maybe developers can add some similar new args
hot_cue macro "loop_in"
or
set_mixpoint macro "loop_in"
geposted Sun 18 Jun 17 @ 8:56 pm
