I miss some of the effects from vdj7 like flanged loop out and delay with the latest updates from vdj8 those effects do not work on vdj8 not even renamed is there any solution to the delay effect echo is not the same as delay so i really need delay effect please help thank you
geposted Mon 19 Jun 17 @ 6:49 am
The old v7 effects are made with another SDK than the ones for v8, so only a few of them work, and some may even cause problems in v8
But V8 has become really good at supporting 32-bit external .vst effects, so you can basically get all the effects you want
Like this one for delay.
I just tested it and it works fine, and has lots of settings.
It even supports the post fader effect option in VDJ, so if that is enabled, it will continue to "delay fade out" after you stop the track
http://www.vst4free.com/free_vst.php?plugin=AfterShock_Digital_Delay&id=2406
Simply download, open zip file, and copy the 32-bit .dll file to \Documents\VirtualDJ\Plugins\SoundEffect
Then restart VDJ and it should be in the effects dropdown
In use (I turned down left and right and only used the center effect)
That's just one .vst. There are many more, so it should be possible to get one you like.
Here are 4 more free .vst delay effects, besides the one I tested:
http://www.vst4free.com/index.php?plug-ins=Delay/Echo
geposted Mon 19 Jun 17 @ 7:04 am
I've now also tested the ATKUniversalDelay
http://www.vst4free.com/free_vst.php?plugin=ATKUniversalDelay&id=2072
That's more simple and easier to use, as shown in this video.
It also supports the post fader effects option like you see in the end
geposted Mon 19 Jun 17 @ 7:16 am
Thank you I will download it
geposted Tue 20 Jun 17 @ 5:34 am
