Topic: Build 3780 Automix points
In the change log for build 3780 one of the fixes is:
"Prevent full start/end automix points to be overwritten when automatically re-analyzing"
When it is stated, automatically re-analyzing, does that also include when I right click on a file and select re-analyze for BPM's etc? If so it does not work. It changes my cue points after I have set them.
geposted Mon 19 Jun 17 @ 11:33 pm
No, when you select reanalyze it is assumed that you want to reanalyze the song and reset the points.
geposted Tue 20 Jun 17 @ 5:09 am
Ok, thanks...
geposted Tue 20 Jun 17 @ 3:05 pm
