Running Mac with 3780 & i have never had this issue. I have 2 controllers, currently for a bar i am using a Hercules RMX2 and i just updated to 3780 and i hear dead air or static in the headphone. I also cue a song and its very loud and distorted, I turn down the gain on the skin and on the controller and same issue. I switch 4 headphones and cords and same issue. I am yet to try my Denon 8000, What can cause this and how do i fix it? Thank you
geposted Thu 22 Jun 17 @ 5:57 pm
Have you checked your audio settings ?
Both on VirtualDj and on your MAC ?
You should also avoid to use RMX2 sound interface for default MAC OS X playback.
geposted Thu 22 Jun 17 @ 6:00 pm
Yes, I checked on software and never never had an issue w the RMX its rock solid and there is no settings that i know of with my mac. i checked on the rmx software and also on vdj where are the settings for this?
geposted Thu 22 Jun 17 @ 6:11 pm
What is the easiest way to go back to the last build on a mac? what are the steps to do that?
geposted Thu 22 Jun 17 @ 6:54 pm
choose the one you want download it install it
http://www.virtualdj.com/download/build.html
geposted Thu 22 Jun 17 @ 7:59 pm
I did that, I re started VDJ and it still says build 8.2 3780
geposted Thu 22 Jun 17 @ 8:11 pm
wickedmix wrote :
Did that and install 3771 and still starts with 3780
geposted Thu 22 Jun 17 @ 8:13 pm
One of my friends, so he got the personal treatment. It was a configuration error, so this is closed.
LOCKED BY AMAHM
EDIT:
Lesson 1. Do not update as you are about to start a gig.
Lesson 2. Save each build download, don't just run them. This way you know what your last build was that worked, so you can reinstall, if you ignore Lesson 1.
LOCKED BY AMAHM
EDIT:
geposted Fri 23 Jun 17 @ 2:19 am
