Topic: pioneer ddj sr crossfader jumping
Good day all,
I'm having trouble with my crossover, every time i place my cross over in the center(50%) from the left or right side it jumps to either side about quarter of the way(25%) on either side when not commanded to.. This Controller is Less than 2 months old always kept in the box it comes in, as case has not arrived yet.. is there anyway to fix this problem? T.I.A.
geposted Fri 23 Jun 17 @ 7:41 pm
I assume you mean "crossfader", "not crossover". Check to see if you have autocrossfader enabled, and linked crossfader. Type crossfader into the search box in options.
geposted Fri 23 Jun 17 @ 7:55 pm
Thanks but its no the auto crossfader is not on.
geposted Fri 23 Jun 17 @ 8:01 pm
The crossfader on the controller moves by itself? What controller is this?
geposted Fri 23 Jun 17 @ 8:04 pm
