Topic: Right platter quit working
Hey need help running the latest 8.2 version MacBook Pro I7 16 gigs of RAM and my right platter just quit working last night on a gig not sure what happened, but I ran into this problem before on my SX2 and also on myERGO , using DDJ RZ.
geposted Sun 25 Jun 17 @ 2:48 pm
Does it completely stop working or just does it change from vinyl mode to nudging?
From vinyl to nudging .
Okay, that is what I thought.
Reactivating the vinyl mode doesn't help?
It does not:( it's weird too because sometimes It does it sometimes it doesn't. I had a seven hour pool party on Sunday and virtual DJ worked flawlessly so your guess is as good as mine
I think I used to have a similar problem when using my Numark NS6. Every now and then one of the platters would not respond to my touch. I noticed that when this happened that if I touched something metal on the controller then the problem would disappear. This pointed to it being a ground or earthing problem. I found that if I plugged the mains adapater for the controller into a different power outlet it rectified the problem. Hope this helps.
Maybe adjust the touch sensitivity if it happens again.
Ok, thanks for your input
