Topic: XDJ 700 with American Audio 10 MXR
Hi guys, I brought the XDJ 700 this my first actual set of a non-controller type system. I am trying to figure them about hit a wall.
1. So the decks same flipped with VDJ when I hit the left deck it goes on deck B and Vice verse
2. I have changed the decks from deck 1 and 2 same thing... even change on the back of the mixer same.
like I said I am new to these deck as well as the aspect of setting, any help will be great. thanks in advance
Both decks are directly connected to my Mac
geposted Fri 30 Jun 17 @ 7:45 pm
Are we talking about control or audio routing ?
Post a screenshot of the Audio tab and the Controllers tab of VirtualDJ settings
What do you mean by .. "when I hit the left deck " .. Which button, where ?
Hey Dj Dad happy 4th..... ok so I figured it out thanks... here my problem now
When I touch the jog wheel to throw the track in or spin it, the track goes crazy.... any ideas
Please explain "goes crazy"..
U mean it moves back/forth way too fast ? Most likely the "Search/Seek" mode is enabled. Even though i dont see anything in the default mapping that could enable this, try to assign a custom button on the skin as .. wheel_mode 'search', see if its ON and if it is , click to disable it.
Unless u provide more details, cant think of anything else atm.
