Topic: Denon DNS-3700 + DJM 800 with VDJ
I have just bought a pair of Denon DNS3700's with a DJM800 mixer, am I able to use this setup with VDJ?
I know the 3700's are supported but not sure about the DJM800?
geposted Mon 03 Jul 17 @ 4:06 am
Yes, you can use this setup with VirtualDj.
The DJM-800 does not have a USB interface and therefore it cannot be connected with your PC. However, you don't need it to be connected. You will route the sound of S-3700 on DJM-800 and you will use it as a standard mixer. VirtualDj can be configured to use the sound interface of S-3700.
geposted Mon 03 Jul 17 @ 5:51 am
How would I connect the 3700's to the laptop? Do I need a special wire?
geposted Mon 03 Jul 17 @ 5:58 am
You need 2 simple USB cables (one for each deck)
geposted Mon 03 Jul 17 @ 6:40 am
Simple enough then. Do I just use the external mixer option in the VDJ options?
geposted Mon 03 Jul 17 @ 7:06 am
Yes.
But bare in mind that this setup will only work for 10 minutes without any license.
geposted Mon 03 Jul 17 @ 7:43 am
Oh I thought I could use the free version with unlimited use. I will look into buying a license.
My decks arrived yesterday but only came with a power cable.
Can I buy any AC to USB lead and line out wires or do they need to be the official Denon wires?
geposted Tue 04 Jul 17 @ 7:58 am
Any USB and Line cables will do. Just don't be too cheap and buy some decent quality cables! :)
PS: I don't think Denon offers "official" cables for any unit!
geposted Tue 04 Jul 17 @ 8:07 am
Yes
geposted Tue 04 Jul 17 @ 11:35 am
FYI that's not an "AC" wire. An AC cable would be a mains cable. USB is only 5v DC.
My advice - don't buy it from Currys. £15 is an outrageous price. You can get something elsewhere for £5 or less.
geposted Tue 04 Jul 17 @ 4:27 pm
I paid £4 each for a 5 meter wire. I got it setup but i had to keep hold of the cue button for the music to play plus i don't have a license.
Can the 3700 use one USB with my music on for both decks hooked up through an ethernet?
geposted Sat 08 Jul 17 @ 12:36 am
I suggest you read the S3700 user manual.
geposted Sat 08 Jul 17 @ 8:37 am
