Topic: Icons for recommended songs?
Hey there!! Sorry if the title sounds weird. I was wondering if VDJ8 had an option like VDJ7 had to have the song icons show whether songs should be mixed together or not? I miss that feature. Not, I'm not lazy; but it does help me make good song decisions. Thanks!! :)
geposted Thu 06 Jul 17 @ 7:18 pm
I don't remember that icon.
Do you mean the ! char?
Sorry, I meant the equal/not equal overlay on songs in Virtual DJ 7 and below. I'll try and post a screenshot.
I would love to have a function like this in GeniusDj.
Like an option to chain files together that we like to mix.
If this was a feature in 7, please bring it back in a better format.
The icon does not recommend songs. It just shows if a song is around the same BPM as the playing one.
I never missed this overlay. But if you want it back you should ask in the Wishes Forum.
You could also still show the bpm difference or key difference column if you want.
Or use the compatible songs filter folder with scope to folder.
