Topic: Icons for recommended songs?
Hey there!! Sorry if the title sounds weird. I was wondering if VDJ8 had an option like VDJ7 had to have the song icons show whether songs should be mixed together or not? I miss that feature. Not, I'm not lazy; but it does help me make good song decisions. Thanks!! :)
geposted Thu 06 Jul 17 @ 7:18 pm
I don't remember that icon.
Do you mean the ! char?
geposted Fri 07 Jul 17 @ 9:21 am
Sorry, I meant the equal/not equal overlay on songs in Virtual DJ 7 and below. I'll try and post a screenshot.
geposted Fri 07 Jul 17 @ 2:23 pm
freppaPRO InfinityMember since 2002
I would love to have a function like this in GeniusDj.
Like an option to chain files together that we like to mix.
If this was a feature in 7, please bring it back in a better format.
geposted Sat 08 Jul 17 @ 9:29 am
The icon does not recommend songs. It just shows if a song is around the same BPM as the playing one.
I never missed this overlay. But if you want it back you should ask in the Wishes Forum.
geposted Mon 10 Jul 17 @ 11:18 am
You could also still show the bpm difference or key difference column if you want.
geposted Mon 10 Jul 17 @ 11:57 am
Or use the compatible songs filter folder with scope to folder.
geposted Mon 10 Jul 17 @ 12:44 pm
