Hi
I am sure there is a really simple reason for this issue as yesterday it was working just fine.
Using the latest version on VDJ 8.2 with a Denon DN-MC6000 (Mx1) Controller and the 2 FX On buttons have stopped working, They are just above the red auto loop button. FX ON 1 (illuminates green) normally comes on when EFX.1 button is turned on. FX ON 2 is something i press and get a little FX effect, it turns orange when i press it normally.
Today both of these buttons are not responding or illuminating when pressed.
I have not made any changes to my normal set up, VDJ did do a auto update when i started the program this evening.
I hope this makes sense, and thanks in advance for your help.
geposted Sat 08 Jul 17 @ 7:54 pm
