Topic: App won't run.
Hi,
So, its been a while since I plugged in my Numark mixtrack quad to my laptop, maybe 6 months or more, so I was expecting a few updates on the Virtual DJ software. After the software updated my laptop says "This App can't run on you're PC' ??? It was working fine before the updates, and my Laptop is only 3 years old. Can anybody help me out??
geposted Mon 10 Jul 17 @ 2:28 pm
Thanks,
That worked a treat :)
my only issue now is I have my Mixer plugged into my laptop and my laptop plugged into my TV via a HDMI cable ( which is attached to a bunch of speakers). I can't seem to work out the correct audio configuration to get it to work. Any help would be fantastic.
Thank you.
TD
