Topic: Software bug in Newest build b3780
Hi Long time user of virtual dj. ( Like over 10 years)
Installed the newest update before a show on saturday. But there is a bug. I am running macbook pro 12g of ram. installed the newest update b3780 I have the NS7ii and the volume from channel two is alot lower. My first thought was that it was a hardware issue. But I opend Serato and both channels are the same volume. Back to VDJ and back to channel 2 not as loud. I would say its a 50% volume drop. I have to adjust my gain pot to the 4:00 position. Looked at all the settings. and see nothing that should cause this. Gain is set to auto. If we can not fix this can you send me the kink so I can roll back to the last version?
geposted Tue 11 Jul 17 @ 11:46 am
Don't think that your issue is related to any Build.
So, you get different output level even if the same track is loaded to both channels/decks ?
Are you using the crossfader or is that disabled ?
Hi yes exact same track loaded in the players I don't really use the crossfader except for scratching. But when djing normally I just keep it in the middle. The exact same tracks or other track loaded in Serato seams to be fine. Any suggestions? You think it is a crossfader issue?
You can try disabling the crossfader in the settings to test without it
You can also test it without a controller to test if it's a "VDJ core" issue, or something related to your controller
I just tested on laptop only with 2 decks, and they both seem to play at the same volume when playing the same track (the exact same file on disk)
Your Audio Setup is Master to Chans 1,2 & Headphones to Chans 3,4, right ? And you have proper pre-listening on Headphones ?
The only thing i can think of, is maybe you have something like Deck 1,Deck 2 in your Audio Setup (instead of the correct Master & Headphones)., thus different output
And the Gains on the skin both show the same db value ?
Master > Numark audio Device > (Bit accurate) CH 1 & 2
Headphones> Newmark Audio Device (bit accuate( Ch 3 & 4
