Topic: Eq
Hi
I have changed my EQ settings to full kill Mode as explained on many tutorial youtube videos but i am still not getting no response from the EQ.
When I change the knob to adjust EQ I am not getting no response.
geposted Sun 16 Jul 17 @ 6:45 pm
what hardware and where are your adjusting the EQ on.
Hi
I am using hardware called : american audio vms5 (digital work station). I am adjusting the EQ on the hardware and i am seeing it change on the software but the sound isn't changing.
Are you using the 'external mixer' audio config as described in the VDJ setup guide?
Do you have your speakers connected to the master output of the VMS5?
The Equalizer is operating in "Hardware" mode with the VMS5, meaning that the VirtualDJ Equalizer. is not used (bypassed) and whatever changes you do in the internal EQ, will not have any impact..
In case you need to use VirtualDJ Equalizer instead of the Hardware, you will need to change the Eq mode and also modify the mapping a bit. Please here for further instructions.. https://www.virtualdj.com/manuals/hardware/americanaudio/vms5/advanced/eqmode.html
hellow, just install virtual dj remote and use to adjust EQ as you want. it is easy.
[Moderation]This post is irrelevant to the OP issue, which is a purely a matter of hardware/controller settings as per the manual.
Please ignore this post and do not reply or comment to it.
hola como estan soy nuevo en la pagina. yo estoy trabajando con viltual 8.3 con el sistema operativo 64bits. pero el viltual que uso es de 32bits y vi un tutorial del viltual dj 8.3 64bits y quiero saber o que me recomienden si lo intalo gracias espero su respuestas
que me recomiendan si lo intalo viltual dj 8.3 64 bits ? quiero saber por queyo trabajo videos y visuales HD y audio
en inglés por favor
Hello, how are you? I'm new to the page. I am working with viltual 8.3 with the 64bit operating system. but the path I use is 32bits and I saw a tutorial on the vdual 8.3 8.3 64bit and I want to know or recommend me if I intalo thank you I hope your answers
hello guys!
im trying to find a way to reduce the bass on my software. is there an equalizer that i can use or download as a free user? ive searched the add-ons and extensions, and didnt find one.
hello
To download Eq10
user19727540 wrote :
hello guys!
In addition to the EQ plugin you find in Extensions (see above), you can also use VST effects with VirtualDJ....
And literally 100s of such available. . From free, to high end pro producer kind..
thanks guys! youve been very helpful!
