Topic: Lock settings
Hi, how can i in lock the "videotransition" and "videoFx", so when i start VDJ, they will be the same?
(although i write/set my favourites in the settings, it always change back to "window" and "camera", when i restart VDJ)
grtz
geposted Wed 19 Jul 17 @ 4:40 pm
What skin is used?
Same appears not in the default skin...
You can add the following script to the ONINIT key of the keyboard mapping.
video_transition_select "VideoTransitionName" & deck master video_fx_select "VideoFXName"
https://www.youtube.com/embed/cL7iPWKWJ8M
If for any reason the selected Transitions/Effects dont get selected when VirtualDJ initializes, you probably spell/type their names incorrectly (?)
The problem seems to be caused by the "saving" method by me or the software when closing the settings.
Solved now.
