Topic: BPM is automatically synced when loaded?
Hello VDJ community,
I just updated VDJ to the latest version and now I have a problem:
When I load a track into a deck it has the original BPM. But when I start this track while another track is running on another deck it automatically syncs the BPM. How can I change this setting?
Thank you
geposted Thu 20 Jul 17 @ 8:56 am
Sounds like smartPlay, check the dot (aka snap button) under the pitch slider.
Yessss, thank you!
One more question: Smart loop is just correcting the length of a loop, right?
Smart loop, yes.
Quantize loop also corrects position to place it perfectly on the CBG (in case you need that option as well)
Since the update it doesn't save the smart settings. Every setting that can be applied to various decks won't be saved in connection with my controller. :/
