I wish to have the possibility to map a Button on a hardware controller to have a Escape fonction to close some dialog box without the use of a keyboard
geposted Fri 21 Jul 17 @ 6:20 am
Which dialog box?
geposted Fri 21 Jul 17 @ 6:49 am
For exemple I want to close the load security box (I don't want to disable it in the options) just to close it as quick as possible without a keyboard
geposted Fri 21 Jul 17 @ 7:57 am
browser_folder, which is mapped to back/folder on many controllers will close most dialogs, such as the load security dialog.
Edit: Your question was answered in your other topic already yesterday, so I'm not sure why you opened another topic for the same question.
geposted Fri 21 Jul 17 @ 7:59 am
In the other topic Reading the answers I thought it was not possible to map a key. So I open this one. My fault sorry. Thanks for jour help, will try your solution
geposted Fri 21 Jul 17 @ 8:17 am
