Discussion about Vocal FX
geposted Fri 21 Jul 17 @ 6:02 pm
It worked at the first time and isn't working any longer. I'm using V8.2, any solution?
geposted Fri 04 May 18 @ 3:28 am
probably need to switch to the correct sample pallet then they will work
geposted Fri 04 May 18 @ 10:10 am
love it but we need some new ones plz
geposted Thu 09 May 19 @ 8:53 pm
virtual dj vocals fx is no longer working can you give detailed explaination how to fix this issues. i.e what is pallet ? where to go setting ? ect because this aint working and boy my mixing is not the same i mix bhangra with urban music so the vocals cut out is important to me...and my fans djprecious !
geposted Wed 19 Jan 22 @ 1:47 am
I suggest you use the stems option instead.
geposted Wed 19 Jan 22 @ 6:00 pm
