Topic: Possible Bug?
Hi,
I use VDJ 8.2 (windows) with a Hercules RMX controller. I have this annoying bug that seems to appear after about 45 to 50 mins into a mix,
where I go to cue up a NON-LIVE deck, use the jog wheel to line up, and it slips the live deck during play.
I pay for this software, (Pro user) and this issue started about 6 months ago, but until now I have persevered - but i'm getting really fed up with it now.
Does anyone else have this issue, either with the same controller or others?
Thanks in Advance.
Aaron
geposted Mon 24 Jul 17 @ 10:44 am
By "slip" you mean it moves/scratch/jump the other deck ? Or a temporary sound cut off ?
If there was a bug in VirtualDJ or default/custom mapping, the issue would appear right from the very first minute.
So perhaps something wrong with the unit itself (some circuit hardware fault - sending wring midi message after some time - overheating(?) ) or a USB communication issue (would recommend starting with replacing USB cable)
