Topic: VDJ not picking up my Mic input
Using a Steel Series gaming headset. I can hear fine, but when I am doing a mic break no one can hear me. My vumeter is moving. The funny thing is it WAS working fine, but stopped in the middle of one of my shows. I am confused
geposted Tue 01 Aug 17 @ 1:02 am
How do you have the headset connected to your computer? What OS are you running?
its plugged in to my audio jacks. I am on Windows 7 Pro, and as far as I know, I have everything configured correctly. I did a clean install of VDJ, and it didn't help.
And you are plugging the dual 3.5mm 3-pole plugs on the headset into your mic in and headphone out (usually red and green respectively) jacks on your computer? Not using the single 4-pole adapter. Got to your VDJ audio settings page and take a screenshot, and your system audio settings as well. Would save a lot of back and forth here.
Sorry it took me so long to get back to you. I am using the 2 3.5mm inputs
I took a screenshot - how do I attach it?
Bump! I still need help with this - anyone, please?
Do you have the mic on, look here.
From what i see in your Audio setup you dont use the headset for your mic line. ??
. Which vumeter are you referring to ? The one in the MASTER center mixer panel on the VDJ skin , right below the MIC Volume ?
