VDJ 8.1 Pro User here, using a Behringer CMD DC-1 Controller....
I see that "Assign Controller" is in the library of commands that can be mapped. My Behringer CMD DC-1 Controller has two different mapping scenarios defined. I frequently toggle between the 2 in a night, and developed the desire to use 2 buttons on my midi controller to change back and forth, instead of having to go into Settings to do it manually. I've tested the assigning of the actual controller (at the Controller level), but I can't figure out the syntax for assigning the controller WITH its associated mapping configuration. The list is:
Controller window: Behringer CMD DC-1 Mapping window: Behringer CMD DC-1 (Raw) and Behringer CMD DC-1 (Club)
Does anyone know the syntax for mapping a button to call the controller (to the mapping definition level)? I feel like this would be easy if I was calling for different controller NAMES, but can you call for the same controller using different mapping definitions?
Thanks,
Doug
Thanks,
Doug
geposted Thu 03 Aug 17 @ 3:17 pm
There is no VDJ Script verb (action) available for changing Mapping files.
geposted Thu 03 Aug 17 @ 3:40 pm
Well, that answers that. Thanks!
geposted Thu 03 Aug 17 @ 3:46 pm
