Topic: No master volume
Hi there,
When I open up vdj and plug in my party mix, there's no output coming from my speakers and only from my headphones.
The interface in vdj does not show master moving at all and all my settings are how they were yesterday when it was alright.
I updated vdj, uninstalled and reinstalled and also restarted my pc several times and it still doesn't work :(
Thanks if you can help!
geposted Thu 03 Aug 17 @ 5:18 pm
Check the Audio Setup tab of VirtualDJ Settings.
If the Master Output is using the PartyMix sound card on Chans 1,2, then you need to connect speakers to the unit.
