Topic: VirtualDJ 8.2 problems
Everything has been running great up until it asked me if i wanted the new version when I opened up it. Every 2 weeks or so when I open it up I will have a pop up that says "Do you want the new version" and I always click yes. Well this time it messed some things up !! I have a laptop that I have my Itunes on and a external list. I can not drag a song out of Itunes and drop it into a virtualDJ folder that I have created. It will also not let me drag a song from itunes and put it into my automix playlist. It seems like everything got messed up after my last virtualDJ update. I wish I would of never exepted the new update.....Unbelievable
geposted Thu 03 Aug 17 @ 10:16 pm
You can go back to a previous version here to see if that was the issue.
If I go back to the last version how do I know which one it was ? If I do this will I loose all of my virtual folders I made of song lists etc. ?
If you open up the config window, the version is displayed in the lower left corner.
Changing versions won't affect virtual folders etc.
I would recommend keeping any VDJ install files you download, so you can easily install without needing to go online.
