I have full virtual DJ 8 pro and I do not have the mapping of the xdj-rx, someone can tell me how to connect it or where I can download the mapping. In the virtual dj I see all the drivers except the XDJ-rx...Thank you
geposted Fri 04 Aug 17 @ 2:03 am
This unit is Recently Added & supported - make sure your VirtualDJ is updated to the latest Build.
http://www.virtualdj.com/wiki/VirtualDJ8%20Controllers.html
geposted Fri 04 Aug 17 @ 5:53 am
You also need to use the login that has you pro license when you login to the software
The one you used to writes this message is a non licensed home user, and that will not work for for more than a 10 min test period
geposted Fri 04 Aug 17 @ 6:08 am
You posted this issue a few days ago. Please do not double post. Please use your first thread to continue this conversation, thank you.
Locked as duplicate by AMAHM
geposted Fri 04 Aug 17 @ 6:12 am
