Topic: build 3846 vfolders
cant seem to move file positions around in virtual folders.
they also are not displaying in the order they were originally in for me.
not sure when this happened or if its intended
I don't use virtual folders often.
thanks for any help.
geposted Sun 06 Aug 17 @ 3:49 pm
I'm not sure that you can move files around in virtual folders. Only order them
I tested it with b3846 and then a few different builds, all the way back to b3398, and it's the same
But I do think I get the original order by clicking the empty column header all the way to the left
the biggest reason it bothered me is they were out of order and I didn't click anything to sort them.
also i didn't see a "Reset Sort Order" on the right click menu.
anyways if that is how they are that's fine just seems weird you can't move them around.
