Topic: Mapping-Problem
I bought a DDJ SX2 and after my mapping, on Thing doesnt work.
The Controller has inside die jogwheel a red LED-"4-part"-wheel.
Standard it flashs only when i scratch.
Now, im am searching the command, that the LED is always on.
What could i do?
geposted Thu 10 Aug 17 @ 5:45 am
This "led" is a Hardware indication that the platter is pressed and its not part of the MIDI, so cant be mapped/controlled.
Really? Because i think the Name is innerjogwheel and it´s mapped in the Standard, too?!
I mean this:
LED_JOG_INNER
That's the key you need to remap
Hallo zusammen! Ich habe ein Problem mit dem Mapping des Sync Buttons!
Hab ihr eventuell den Befehl dafür?
Hab einen DDJ SX!
Vielen Dank schon mal!
Hab in den Foren schon geschaut aber nichts hilfreiches gefunden!
sync
But here You better speak english.
Hello everybody! I have a problem with the sync function! And you need yours Help! I have not found anything in the forums! What is the command for the
Sync button? So that he adjusts u back to real bpm? Thank you
As above, the default mapping for the SYNC botton on the DDJ SX is just
sync
Try this:
param_equal pitch 0.5 ? sync : pitch_reset
I also faced this kind of mapping problem
